It is currently Sun Jul 20, 2025 10:03 pm
PostPosted: Fri Aug 17, 2007 11:54 am
I'm following Cupiano's book, although not his dimensions, and I need some help. I'm building a D********** based loosely on an Gibson AJ. Based on some research I've decided on a scale length of 25.5". So, here's my question. What should the length be from nut to neck/body joint? Should it be exactly the scale length from nut to 12th?
Side note:
I started this guitar about 10 months ago, so it was before the AJ OLF plans were out
nay
My blogs
Hand Made Gutar
Woodworker++
PostPosted: Fri Aug 17, 2007 12:58 pm
Nathan,
Here's a link to StewMac's fret scale calculator. Plug in some numbers and it will give you all the info you need. http://www.stewmac.com/FretCalculator/
I'm lazy and have LMI cut my fret slots. I then use the fretboard as a ruler for laying out my neck. That's one less opportunity for me to mis-measure something...
Bob K
PostPosted: Fri Aug 17, 2007 1:09 pm
Thanks Bob, but it's not the fret slots I'm worried about. The fret slot position I can figure out from the scale. I'm trying to figure out where the actual joint for the neck to the body should be in relation to the nut.
nay
My blogs
Hand Made Gutar
Woodworker++
PostPosted: Fri Aug 17, 2007 1:12 pm
It should be the distance from the front of the nut to whichever fret joins
the body.
PostPosted: Fri Aug 17, 2007 1:20 pm
Exactly like James said. I should have been more clear, I use slotted fretboards as a story stick for laying out my nut and neck joint placement.
PostPosted: Fri Aug 17, 2007 1:26 pm
EDIT.
Oops. And whether it's a 12, 13 or 14 fret neck joint depends on how you laid out the body, soundhole and braces. My main concern would be that the bridge lines up with the bridge plate.
PostPosted: Fri Aug 17, 2007 1:27 pm
It depends on your scale length and what fret you want at the body joint.  Once you know that, you use the measurement from the nut to that fret as your distance.  For example, a 25.5" scale length which is what you said you are using, 14 fret to the body guitar would have a length of 14.141" from the nut to the body.  If you go with a 12 fret to the body, then the length would be 12.750".  Hope that helps.
PostPosted: Fri Aug 17, 2007 1:42 pm
Great, thanks guys. I did want the neck to join the body at the twelfth fret. I had assumed it would be the same distance as the scale of the 12th I just wanted to make sure. Thanks again!
nay
My blogs
Hand Made Gutar
Woodworker++
PostPosted: Fri Aug 17, 2007 2:15 pm
Someone needs a spell checker.
